Axel Kollmenter
Which is what I use instead of the Onshape material library.
Keep in mind, if you modify any property of a part, then a featurescript will be overridden until you press the 'reset all' button in the property menu..
otherwise, create an improvement request.
Until then, here is my material FS you can copy:
FS: Set Material | Set Material (onshape.com)
Looking forward to some new surprises.
