How can I select 'the other line' when editing a Sketch?
john_smith077john_smith077 Member Posts: 175 ✭✭✭
Hello
When editing a Sketch, where two lines are in exactly the same place (e.g. a dotted line and a solid line), is there any way to select "the other line" from the one OnShape first offers you when you Left-Click on it?
Many thanks
J
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    Press key above tab key (~) or right-click to get “select other”
