How to build a part on top of another, with middle points over each other
VoyagerVoyager Member Posts: 19 EDU
Hey, I would like to extend my part, like on the picture:
The middle point of the two rectangles should be over each other (black line), how can I do this?
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    Very simple in Onshape, just take a look at the learning centre.
    https://learn.onshape.com/courses/mastering-top-down-design
  • SethFSethF Member Posts: 132 ✭✭✭
    I agree with Dirk, I think you'd benefit a lot from the learning center.
    That being said, I'm guessing you need to just change on option in the extrude for your second part from "Add" (which adds the extrude to the existing part) to "New" (which creates a new part).
    Here's an example.
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    To EXTEND as it appears in your red line work
    You could go back to the feature that made your sketch a 3D part, which was most likely an extrusion, and you could EDIT that extrusion
    Or, you can use a tool called MOVE FACE
    But you really should do as Dirk and Seth said which is to go through the training courses
