sheet metal: questions regarding corner treatment
in this document, i've tried several SM things:
https://cad.onshape.com/documents/3282f67f328e68e36f02a626/w/7d90ff8c606025b970e9ba14/e/f89e6309230563660cd3cf53?renderMode=0&uiState=62aca89842cf476aed97baba
1) why is it not working to move corner treatment (Ecke 1) behind the following extrusion (Linear austragen 3) ??
2) why is it not working to close Corner 1 and Corner 2 similar to Ecke 1 ??
3) what kind of workaround exists to close corner 1+2 ??
thanks IA for any good idea
bryan_lagrange Member, User Group Leader Posts: 866 ✭✭✭✭✭
@Ulrich_Hanisch I will admit, Onshape sheet metal is in the beginning stages. It can create some interesting situations. Here is another way I was able to get what you were looking for. I moved the flanges at the end of the model tree and use a closed joint command.
https://cad.onshape.com/documents/6acd89b0c28e0348724f96c5/w/df2f572542a20ce2e698bf48/e/8095a449f70e880fddee2902
Axel Kollmenter
I hoped, that in Onshape, the SM design would work more flexible and more robust than in Solidworks
Twitter: @BryanLAGdesign
it should be accessible with link, and i've made it public
https://cad.onshape.com/documents/a5026bfede4af26d309a7085/w/e72f9a453c8aeccc58bbbcf0/e/92e6602b49fcb6629dfd8395?configuration=List_DGbyxZJkgMO1Vw=Default&renderMode=0&rightPanel=configPanel&uiState=62b16f8a9395707c52c3032c
The strategy, which isn't working well, is to create flange by flange separately. There you have almost no chance to get the corners closed.
