obj import mesh.
s_t185s_t185 Member Posts: 2
im using software to generate an obj file, i can produce this and import into onshape and it only creates a `part` and no meshes.
how can i get onshape to recognize the meshes ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    "Meshes" as an item in the Parts List do not exist anymore they are all just Parts now, but you should be able to see the mesh.
