Can I derive parts from few tabs at once?
ben_partouch
Member, csevp Posts: 158 PRO
Deriving 15 parts one by one is very time consuming.
Thanks
Thanks
Normally if I was building a part which was dependent on 15 others, they would all be in the same part studio, or perhaps they’d be in an assembly and I could use assembly contexts.
Yes I can definitely explain- I'm making kitchen cabinets. Each box is a configured part. Than I need to take all these boxes to a top level part studio so I can AutoLayout all the parts for CNC machining. (This might change as I we looking into CAM that nest parts out of a 3D model). The other benefit to working in part studio for top level is that I can make changes to all the boxes at once.
I hope that make sense, Thanks.
Lead Mechanical Engineer @ Healing Innovations
@MichaelPascoe to be honest I'm trying to move away from nesting parts inside OS. Hopefully soon will have a CAM that does that.
But I would like it to be able to handle large amounts of sheets- It failed on me once working with more that 13 sheets (I need 25 and more sometimes).
Also rotating (mostly for grain direction) and flipping sides without using transform would be nice.
Thanks guys!
there is no optimization for nesting small parts within voids of larger parts.
there is no optimization for nesting two triangles together even.
I use it to get a sheet count when quoting, the low optimization tells me the maximum number of sheets required.
We use Radan and Radbend for sheet-metal.
They work pretty well.
Before that we used Mastercam which was also good.
Derive is one of the slowest features.
So, it would likely be more efficient to have a couple of parts in the single part studio if they share many features.
Then you would be able to derive once and get multiple parts from one rebuild cycle.
I get that
