Featurescript Wiring
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
I´m using your Wiring Featureskript and I would like to know if I can access the automatically detected length of the cable to automatically load it into my cabling table in the drawing.
Best regards,
Axel Kollmenter
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Hi Axel. Currently there is no way to get data into drawing tables automatically. The script could be modified to write a parameter or variable but there would be no way to get it into a drawing. I am working an a potential solution to this but it’s a few weeks away.
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    Alright... thanks for your answer! :)
    Best regards,
    Axel Kollmenter
