Export of Onshape assembly not using .step (but with the features thereof)
Lasse_Karlsson_CA
Member Posts: 11 PRO
Hi all,
I'm having a bit of trouble with the .step-export feature. The generated files sometimes contain extraneous features that cause problem downstream in our toolchain.
Examples:
- a sphere being exported as a (degenerate) toroid.
- a spline cutting a conical object leaving the entire cone in the generated file.
- a sphere that cuts part of a complicated object leaves the sphere in.
As of yet I have not been able to pinpoint a smoking gun which triggers this.
What I really need for my use-case, is a way to extract a boundary representation of an onshape assembly where I can keep the part names intact. In theory this ought to be solved by the step-exporter but in practice for my purposes this feature is not reliable enough.
Any ideas anyone? I've been through most (if not all) file export formats provided by onshape, but none seem to provide the same functionality.
cheers
Erik
Erik
I have generated a support ticket on the issue so I assume that someone is working on fixing the step-exporter. The reason for this discussion was I hoped to find some kind of work-around in the meantime.
The geometry here is a sphere (radius 5cm ) with a spherical void (radius=2.5 cm) inside.
What I had hoped for was suggestions for working around the issue through some other means than direct .step export. Maybe I was not quite clear about that in the original post.
