Heat Exchanger
I cannot get this tube of the heat exchanger to connect properly in the correct plane. How do I get this to the regular screen, without the assemblies column?
S1mon Member Posts: 3,378 PRO
Is there any special reason that you're using a part studio instead of an assembly? After you create one of the radiator parts and one of the 180 degree bend tubes, you could just do the rest in an assembly. You also probably want to make the tube have some wall thickness.
If you haven't already, you might want to go through the training. There's a lot available.
https://learn.onshape.com/catalog?labels=["Self-Paced Courses"]&values=["CAD Basics"]
1
Without a link or a picture or a better description, no one can help you. Neil is being sarcastic (I think) because there's nothing to see.
My apologies, silly me. Ok I want to put that tube in the center. Please hellp.
