Heat Exchanger
Please show me how to connect the tube in the middle, in the correct plane.
https://cad.onshape.com/documents/45420a115af55cf68a7f1d20/w/f9be989edcbad8f324541769/e/bd3c0fa368dcc58ca0141e26
Twitter: @BryanLAGdesign
I agree this should be an assembly.
There are a ton of transform features that don't seem to be doing anything useful so I am not sure what the intent is...
Note that you don't need to create mate connectors to use the "transform by mate connectors", you can just use implicit mate connectors. I also noticed the "elbows" are more than 180deg for some reason. The fins for the heat exchanger didn't have a "merge scope" but adding the tube removed the need to create a composite part as well (and there will be better flow with a hole for the tube in the fin... ;-p). Also a great place to use the "linear pattern +" feature for better control!
This should be all you need:
https://cad.onshape.com/documents/da40aa8a191905fbb0885946/w/097ce39f2428f507fcbf5be5/e/b288310dfc3dd48f5f284b0f?renderMode=0&uiState=62c8a7dea1cf084be5e5508c
I agree with @S1mon, @bryan_lagrange, and @eric_pesty
https://www.youtube.com/c/OnshapeInc/search?query=assembly
