Trim a face
eric_pesty Member Posts: 2,127 PRO
@Axel_Kollmenter
Not sure what it's called in German but here it is:
And here's an example:
https://cad.onshape.com/documents/9eb6fafc8bc223165a3cb5f6/w/e03d9e774b5862665d172916/e/7fbdc1d6d5ef25e67904083e
Edit: you can even be more explicit about the final length using the "up to entity" with offset:
3
You could use the split command with a plane or mate.
A "replace face" with an offset should also work.
Sorry, my mind read sketch where you said "mate". I find I rarely create planes in Onshape when in many cases you can just use a mate connector as the input for a feature.
I also always chuckle when I see an example or answer that includes creating a plane to place a sketch (like on the end of a line). Clearly "old habits" from other CAD systems!
Axel Kollmenter
The split feature with mate connector would also let you realign the MC to be parallel to the angled face (or any other angle) but that would be more work
Axel Kollmenter
I created the profile, copied the longer part, and the transformed it to the right side. then I used the boolean operation to join both parts. But in fact that I copied the longer profil, the profil on the right is too long.
Axel Kollmenter
Axel Kollmenter
https://learn.onshape.com/courses/frames-fundamentals
Axel Kollmenter
