Mesure distances in section view
brunono553
Member Posts: 16 ✭✭
Hi,
I'd need to be able to mesure distances while using section view; exactly like if I cutted the parts I need to mesure by the section view plane. Something like this: (I actually cutted the part for doing measurements)
So I've to branch, then split. Quite an heavy process for a simple measurement
Just remember to go back to main for your real work! I have found it tricky to know which version I'm in and have spent hours making changes to the wrong branch before... Perhaps there is a way to be notified or make it clear if the user is not within "Main".
It looks like this feature hasn't been implemented yet. Any plan to add this?
It's there. You need to section, then select the measure tool.
