VIEW SIMPLIFICATION
shawn_crocker
Member, OS Professional Posts: 914 PRO
in Drawings
What the ... does "Simplification threshold: features below this value will be simplified" mean? And why does it seem any time I attempt to change this to simplify my view, nothing appears to happen other than I have to wait 5 years for the drawing to apparently rebuild itself? What is "this value" that the little tool tip is referring to? Basically what I often want to do but don't have time to experiment with my drawing reloading seeming endlessly, is make a small view that looks like a black blob due to all the excess detail, not look like a black blob.
mfalkensteiner
Member, Onshape Employees, csevp Posts: 87
It always references whole features. So I assume there is something in the feature that is higher than the threshold.
Principal Technical Services Engineer, EMEAI0
Enter a number in the length units of the drawing to indicate that any feature smaller than the value will be simplified within the view. If whole parts are smaller than the threshold value, those parts will be missing from the view. This is useful for removing excessive details not needed for drawing purposes (for example, a large number of very small features or components).
I didn't notice the little units symbol on the absolute setting. I am still not seeing anything happening when changing the setting. I have even tried setting this to 2IN and still details that are 0.11IN apart remain in the drawing view. I certain there is something really obvious I'm not understanding here. Check this little .gif.
