Hole Tool Feature Question
What angle (drill point angle) is left in the bottom of a blind hole? Is this going to be adjustable?
What angle does the countersink leave? Is this going to adjustable?
70.529 deg (?????????), doesn't currently appear to be adjustable
I'm guessing this is a preliminary teaser, not a serious proposition
Whats the purpose of these angles? Weird.
Like all features, hole is a feature we are working on iteratively. Please post additional things that you need/wish for in a hole feature.
@3dcad had some particularly inspiring examples to do with positioning hole patterns relative to a corner of a mounting feature, and then being able to flip the same hole, or hole pattern, to the same relativity vs the other corners. It would be nice to see a seamless integration into linear and circular pattern tools, too, (or if patterns are made integral with the hole feature, the UI should look and feel the same, to the extent possible).
I would urge that attributes be easily and smoothly customisable, and those customisations need to be easily saved, possible in multiple sets. If someone has developed a cool way of threading holes within 0.5D of the bottom of a blind hole on a particular machine or process, it's galling to have some piece of code repeatedly over-ruling his or her judgement, or saying it needs to be 1.5D minimum. Or whatever.
PS: If the default drill tip angle is to be 118 deg (I'd be perfectly happy with a round 120, personally), can I respectfully request that the countersink angle be 90 deg (by the same measure), not 45?
And absolutely, let these parameters be customisable (particularly the drill tip angle; we can easily use "chamfer" for countersinks at non-standard angles)
I really like the way the hole position sketch has been treated as a separate issue from actual faces on the parent part.
If only this crystal ball had been looked into a bit more closely in Solidworks' Hole Wizard's early days.
I lost count of how many times I clicked on the wrong thing, and got shunted off into the wrong interface (3D vs 2D sketch), before I unlearned the previous behaviour...
(Refer https://cad.onshape.com/help/index.htm#cshid=hole
... "Steps to create counterbore holes", which shows an instance of inserting holes on a non-planar face)
Haven't yet got around to finding how to distribute holes around a conical or cylindrical (or, dare I say it, compound curved!) face in Onshape. I'd be surprised if that was baked already, and if not I'll try to come up with some helpful suggestions.
1) A drill index. Standard (letter, number and fractional drills). Metric drills
2) Tap drill selection- based on desired thread percent.
3) Ability to adjust drill (and and countersink) angle.
I have to say that at first encounter that part looks seriously smart.
The ability to use multiple sketches, with different directions, is impressive, and particularly the apparent intelligence, namely the way hole starting planes are decoupled from sketch plane location (of course, that degree of machine intelligence, if there is no possibility of intervention or correction of aberrant cases, has to meet some thorny challenges before it proves itself!)
In relation to 'different directions', I do have a question about parts where the hole direction is ambiguous - Imagine a part where extensions of the solid wrapped around both sides of the plane with the sketch points: How do the holes know which extension is the one we want the hole to penetrate?
I'm thinking we may need some way to "flip" the orientation of a plane - I would rather that was added, if need be, rather than just see the hole feature tool 'enhanced' to enable holes to be flipped.
I say this because control over the direction of planes will have multiple benefits further down the track.
I say this with some confidence, because certain quite high-end modellers have failed to provide this (and sometimes it sucks)
