can you create a subroutine?
billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,115 PRO
Let's say I want to format the output for a vector
function printVector(v) {<br>   println("vector :"~roundToPrecision(v[0], 4)*1000~", "~roundToPrecision(v[1], 4)*1000~", "~roundToPrecision(v[2], 4)*1000);
<br>
How do I call the function?
printVector(v);
  • MichaelPascoeMichaelPascoe Member Posts: 2,597 PRO
    edited July 2022
    printVector(yourVectorHere); should call your function. Perhaps I'm missing something.
    If your function is stored in another studio, you will need to place "export" before the function. Then you can import that studio into your current studio to use it like you normally would.
    FeatureScript 1803;
    import(path : "onshape/std/geometry.fs", version : "1803.0");
    annotation { "Feature Type Name" : "function" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            // Define the parameters of the feature type
            function printOut(m) {
                print(m);
            printOut("hello world");
    <br>
    It's seems simple but I can't find any reference to functions or subroutines, I have seen other code where guys are passing the context into functions outside the "function action area" and was wondering if there is something printed in the manuals about this simple concept.
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 164 PRO
    Ah, that's because you want to create the function outside of the precondition and feature body blocks of code. You're looking for
    FeatureScript 1803;
        precondition
            printOut("Hello world");
        print(m);
    chadstoltzfus@premiercb.com
    edited July 2022
    Another quick tip while my brain is thinking about this, sometimes you'll deal with vectors that have units, other times you'll have vectors without units. I would recommend checking the data type in the print function. Usually you would create an overloading function, but Vectors are the same data type whether the contents of the array are a number or a ValueWithUnits.
    FeatureScript 1803;
    annotation { "Feature Type Name" : "My Feature" }
        precondition
            // Define the function's action
            var vectorWithUnits = vector(0, 0, 1) * inch;
            var vectorWithoutUnits = vector(0, 0, 1);
            printVector(vectorWithUnits);
            printVector(vectorWithoutUnits);
    export function printVector(v is Vector)
        if (isLengthVector(v))
            println("vector :" ~ roundToPrecision(v[0] / inch, 4) * 1000 ~ ", " ~ roundToPrecision(v[1] / inch, 4) * 1000 ~ ", " ~ roundToPrecision(v[2] / inch, 4) * 1000);
        else
            println("vector :" ~ roundToPrecision(v[0], 4) * 1000 ~ ", " ~ roundToPrecision(v[1], 4) * 1000 ~ ", " ~ roundToPrecision(v[2], 4) * 1000);
    @chadstoltzfus perfect. That's what I was looking for. Thanks
