can you create a subroutine?
billy2
Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,118 PRO
Let's say I want to format the output for a vector
How do I call the function?
function printVector(v) {<br> println("vector :"~roundToPrecision(v[0], 4)*1000~", "~roundToPrecision(v[1], 4)*1000~", "~roundToPrecision(v[2], 4)*1000);
<br>How do I call the function?
printVector(v);
If your function is stored in another studio, you will need to place "export" before the function. Then you can import that studio into your current studio to use it like you normally would.
FeatureScript 1803; import(path : "onshape/std/geometry.fs", version : "1803.0"); annotation { "Feature Type Name" : "function" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type } { function printOut(m) { print(m); } printOut("hello world"); }); <br>It's seems simple but I can't find any reference to functions or subroutines, I have seen other code where guys are passing the context into functions outside the "function action area" and was wondering if there is something printed in the manuals about this simple concept.
function printOut(m) { print(m); }chadstoltzfus@premiercb.com
FeatureScript 1803; import(path : "onshape/std/geometry.fs", version : "1803.0"); annotation { "Feature Type Name" : "My Feature" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type } { // Define the function's action var vectorWithUnits = vector(0, 0, 1) * inch; var vectorWithoutUnits = vector(0, 0, 1); printVector(vectorWithUnits); printVector(vectorWithoutUnits); }); export function printVector(v is Vector) { if (isLengthVector(v)) { println("vector :" ~ roundToPrecision(v[0] / inch, 4) * 1000 ~ ", " ~ roundToPrecision(v[1] / inch, 4) * 1000 ~ ", " ~ roundToPrecision(v[2] / inch, 4) * 1000); } else { println("vector :" ~ roundToPrecision(v[0], 4) * 1000 ~ ", " ~ roundToPrecision(v[1], 4) * 1000 ~ ", " ~ roundToPrecision(v[2], 4) * 1000); } }chadstoltzfus@premiercb.com
