Problem using the thicken and/or shell function on part
laurent_beardselllaurent_beardsell Member Posts: 2 EDU
Hi, I'm having some problems using the thicken or shell function on this part, It works up to 5mm but anything higher fails. I suppose the angles or curves are too thight but I cant figure out why and how to change them to make it work without affecting the resulting design too much. Thanks for any help on this!
https://cad.onshape.com/documents/c01124e2109d707ce28c7de8/w/ee83d447c94dfcedebcf5a0f/e/7ed1566c3a53e20bdad36634?renderMode=0&uiState=62e17010890cae5c37b7bc59
  • Phillip_BPhillip_B Member Posts: 34 PRO
    The curvature quality in the front area is pretty poor:
    I suspect that's where it's running into problems.
    Try modeling the surfaces with better curvature transitions, then it should probably be fine.
