how do you make sheet metal models with arbitrary miters and many different levels
I am working on a project and in it, there is a part that is built of multiple plates of metal mounted at a multitude of angles.
it is difficult to explain but the issue I am running into is I need to make a flange that connects to another part with a miter on either side that has different angles. and Iyet  can't find a way to do this
any ideas on how to do this
    dirk_van_der_vaartdirk_van_der_vaart Member Posts: 543 ✭✭✭
    Have you had a look at configuration's??
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,415
    @eric_smith487 can you share the URL plus some screenshots of what you are trying to do?
