Two stl files into one Part
joerg_manijoerg_mani Member Posts: 2
Hi
My question is actually simple.
How can i combine two stl files into one? The part is in two pieces and i do have only the stl files. My 3D Printer is big enough so im able to print it as one part.
I tried it to import it and to create an assembly that worked. Is this the correct way to do it or is there a better way to create one stl file?
Thank you in advanced for your answer.
Cheers from Switzerland
    @joerg_mani, you may be able to accomplish this task in your slicer.  Cura has a right-click option to "merge" models.  Presumably other slicing engines offer similar capability.  Your two pieces may well have been modeled together, in which case "merging" them in the slicer will locate them together and print them as one.
