Having trouble mating 2 parts in an assembly
paul_bartlett
Member Posts: 91 ✭✭
I have these 2 parts aligned almost the way they need to be mated. I can not for the life of me figure out what mates to use. I've used a lot of different ones and get weird results every time. The groves won't all line up but that's something I can probably fix. Once these are mated properly I will mate 2 of these assemblies in a similar fashion so they create a continuous loop (Ribbon)
https://cad.onshape.com/documents/15068bf618aded5c3c8097c2/w/b2bdd24ff94cf9d7bc7531f4/e/bc6beab2efd01cbf69add041
https://cad.onshape.com/documents/7bcf9a9d656a7af9f8c945cc/w/5150b20fb3a508ab93249ecf/e/3984a62db59474368f832aa0
If you are curious about an easier way to model in order to get all the ribs aligned in the assembly, take a look at this
Everything done from the center out.
https://cad.onshape.com/documents/6f149c0a2c4dac073726befa/w/5be169b47a88c137c95eb777/e/f5c9746a808665f37a1b0783
It made me happy hearing that you liked it
