Checking concentricity between holes
gil_maor
Member Posts: 5 ✭
Hi All,
I have an assembly and where the parts are connected with bolts.
How Can I check That all of the holes are concentric?
How Can I know If I moved a hole that it is out of alighment.
Currently I am using the "fastened" mate and It affects only one hole.
Thanks!
Gil,
Thanks!
Gil,
All you need to do is create an in-context part studio, and select all of the holes you want to check.
The first hole is the reference hole (which will appear blue).
Holes in-line will appear green.
Holes not in-line will appear red.
I'll create documentation at a future date.
But give it a try, it should solve the problem.
You can get it here:
Concentric Checker
I was looking for a method that will not require me to go over each and every hole.
The second approach is super!
thanks!
