Is there a way to paste some data into a generic table drawing other than one cell at a time?
eric_pesty
Member, pcbaevp Posts: 2,529 PRO
in Drawings
I have a table of data generate in excel (30 rows x 5 columns) and I want to put this on a drawing, however I can't seem to find a way to paste data across multiple cells...
I can paste a bunch of data into one cell of the drawing table but that's not helpful... I refuse to believe it can't be done, am I missing something obvious?
I really don't want to copy/paste 150 times!
3
Haha! I also can't seem to find a way to do this?
Thanks for trying! I got confirmation it's not currently possible, which is pretty crappy and disappointing...
My workaround was to paste each column into its own cell so I only had to paste 5 times. At least that way it's still text, it's just one row...
You really would expect that if you select data from a table and paste into another table structure it would figure out what you are trying to do. Especially since copy pasting in Onshape tables (mostly) works for config/BOM tables!
Twitter: @BryanLAGdesign
Interesting, I might have to check that out, although it seems like a very convoluted way to get to what I want...
It seems like a fundamental design limitation in the drawing tables: you can select multiple cells to apply formats etc... But you can't affect the data in a cell without first "entering" that cell. Even selecting a cell and hitting the delete key doesn't affect the data like you would expect so it's no wonder you can't paste across multiple cells.
Seeing you could import a JSON I was hoping to circumvent the google sheet part (it's not really part of my workflow here). It's easy enough to convert data to a JSON table so I tried that but I got an "unable to retrieve BOM data" error.
Part of the issue might be that it's intended to be a BOM rather than just a generic table... I'll have to dig into a it a bit more to see if I can spoof it...
EDIT:
@bryan_lagrange
Can you paste the raw JSON code it spat out in here (should just be plain text)? It looks like there are a number of ways to describe tables in JSON and it might be expecting a specific one...
Thanks,
Thanks, that looks like a lot of extra "baggage" just to display 3 cells!
Did a quick attempt at "hacking" it but didn't work... I'm going to do an IR to allow inserting a "generic table" in a drawing (from a JSON... or CSV)
Hi, this was bugging me too, as a lot of my BOMs are in refined/processed in excel.
So I dug in a bit today and wrote some VBA code to create a "Save as JSON" excel button that works for Onshape.
to this...
WARNING / DISCLAIMER: This is a total Hack. I have very little coding experience and I've not extensively tested it yet, but it seems to work for at least this one simple example. I don't really have time to support or refine this code but hopefully it will be useful to some.
Thanks go to the following tutorials
This is good for finding the data range in a spreadsheet...
https://www.youtube.com/watch?v=6PLmcweo50I&list=PLKbOx3gUV_E-udcFZb40qMTaHz6hyf2Nq&index=3
____________________________
