How to reach the bottom of a long feature panel?
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 255 ✭✭✭
edited August 2022 in Community Support
Occasionally a feature panel is longer than a screen (see the red highlight in the example of the changed Flange feature in the latest update 1.151). Then I can't reach the bottom.
Is there a way to get to the bottom without changing the screen resolution or should a slider (here gray) be added to a panel as an enhancement in this case?
Henk de Vlaam (NL)
  • EvanReeseEvanReese Member, Mentor Posts: 2,445 ✭✭✭✭✭
    you can click the little "V" shapes to collapse that part of the UI
