Scaling dimensions in a sketch
I have a sketch I have drawn in 1:1 and I would like to copy it and reduce it to 1:87. I have completed this on a basic shape, but have been unsuccessful in sketches with more complicated geometry. I have been doing this on a feature-by-feature basis - i.e. (120/87) in. Is there a function that would generate the needed conversion globally within the workspace instead. Here is the link to the file: https://cad.onshape.com/documents/def726104d60f270e126d3e7/w/5f6ef42e6e28571c9d3e6a99/e/59acc8572b69289114fb59e4
Thanks in advance for the assistance.
colin_king506 Member Posts: 43 ✭✭
I have Transform and Warp, no Scale. When I went to About I only found this - 1.151.6014.5861c52f57df; I'm imagining it is the ver. #?
Eric,
I approached it again with a fresh perspective and see what you mean the dropdown within feature Dialog Box. I thank you.0
If you have an assembly you won't be able to do this directly but depending on what you are trying to achieve you might be able to create a new in context part, select everything and scale that (with "copy" checked). This creates a new set of parts all scaled down rather than scaling the original parts but might get you what you want?...
