How to bend a flat extrusion around a curve
I made a Championship style belt plate, but it is a flat extrusion. I am unable to figure out how to bend or Flex it so that it would have the curved shape like it should have on a championship belt.
Is there a way to do that? bend an existing extrusion model across an arc or something?
https://cad.onshape.com/documents/80efdae47262ec44ac1b44da/w/a0250d6607f3e6a7e5561b6d/e/bd00771bd3597e0747bbe9b6
Then you could wrap each of the sketches SEPARATELY and thicken them SEPARATELY. Using this technique, it made it far easier for me to thicken the two separate entities of the buckle I made
In any CAD program, make good effort to keep your sketches from becoming overly involved. In other words, instead of trying to do it all on one layer, break it out into multiple layers. In the case of Onshape, break it out into multiple sketches
in your case, I probably would’ve used — I don’t know — maybe six or seven different sketches. Maybe more
Now, there’s another aspect of this that I’m not crazy about. And that is, that it appears that you were snapping to or going coincident to some underlying vector file — which I can’t see.
Myself, I’m not crazy about having all these coincident points to an underlying file. I’ll trace over the underlying. But I don’t want to make everything coincident to that because — for one example — you could see that without having that underlying vector — I get nothing but a bunch of overdefined constraints when I first open up your document. And that’s not great to work with
For instance, instead of making a curve this way
Again — this is a matter of making things more manageable or easier to edit, smoother — all that kind of stuff
https://cad.onshape.com/documents/4d056f95662ea71348229f52/w/61bb36ffbc357eab95773f52/e/d2d3155acfe9bf4d136a82d6
That,s helping, a very nice present!!!!!
Thanks Dirk !
I really appreciate it
You are on a holiday?
