Boundary conditions
sebastian_glanzner
Member, Developers Posts: 481 PRO
in Simulation
I like the approach that Onshape Simulation uses the mate connections to transfer forces between parts.
But in my opinion there is a problem that we can't create boundary conditions.
At the moment we have to fix one part of the assembly, so we don't have rigid body motions in the simulation.
I created a simple table with four table legs and a table top. Which part should I fix to create a simulation?
So I create a floor, which means I have to create a new part in a new part studio. Then I have to assign a material to the floor to be able to run the simulation. Even the floor is not moving or deforming. Then I add the floor to the assembly which changes the total mass of the assembly. And the floor is changing the BOM because it is a new part.
Finally I have a running simulation of the table with a floor:
But you can see that all legs are sticking to the floor and they are not sliding. This artificially increases the stiffness of the table.
Normally I would have fixed only the lower surface of one leg. The other three legs should be able to slide over the surface.
So I create three new planar mates at the bottom of the legs:
Now the legs can slide on the floor and I get a better result. (An even more accurate result would be the legs could only transfer pressure forces.)
If Onshape users could define boundary conditions in a similar way like they define the loads.
I could have made the simulation in the original table assembly, without the following:
What do you think? Is there a plan to introduce new commands to create boundary conditions?
- Creating a new part-studio to create a floor part
- Inserting the floor in the assembly, which changes the total mass and the BOM. (This could also make trouble if I would make a Release Candidate, because the floor would require a part-number)
- Changing the fixed part to floor
- Creating new mates between the legs and the floor
