Sharing documents with non-Alpha users
julian_lelandjulian_leland Member, OS Professional, Mentor Posts: 59 PRO
I have a document that has the Drawings Alpha enabled, which I'd like to share with other users. Is this okay to do, or will it break/expose something that shouldn't be?
  • julian_lelandjulian_leland Member, OS Professional, Mentor Posts: 59 PRO
    Just to clarify - I want to share the model, not the drawings. I don't care if they can't see/modify the drawings, I just don't want to get in trouble!
    @julian_leland Actually you won't be able to share the document at all with a user that doesn't have Alpha Drawing capability. I certainly hope for alpha to progress into beta sooner rather than later for this reason. I actually feel that it may be developed enough for beta, sure were missing a lot of functionality but were missing functionality in the modeling side also.
  • bobminerbobminer Moderator, Onshape Employees, Developers Posts: 50 image
    @julian_leland - Please contact @lougallo and we can discuss options to help you out.  In general, we're hoping to transition from drawings alpha to public beta asap.
    Bob Miner - Software Engineer / Dev Leader - Drawings - Onshape, Inc.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    Typically you will see something like this:
