How to mirror a feature?
sebastian_rigger837
Member Posts: 1 EDU
I would like to mirror the opSweep and opBoolean function, on the opposite side of a cylinder.
The documentation says, that i need a featureList as an input for the instanceFunction. Could not find out, how i can construct it.
Or is there another way I could achieve this??
opSweep(context, id + "sweep1", {
"profiles" : qSketchRegion(id + "sketch1"),
"path" : qUnion([qNthElement(edges1, 0), qNthElement(edges2, 0), qNthElement(edges3, 0), qNthElement(edges4, 0)])
opBoolean(context, id + "boolean3", {
"tools" : qCreatedBy(id + "sweep1", EntityType.BODY),
"targets" : qCreatedBy(id + "extrude1", EntityType.BODY),
"operationType" : BooleanOperationType.SUBTRACTION,
"keepTools" : false
opPlane(context, id + "plane1", {
"plane" : plane(vector(0, 0, eLength-(definition.lPiston/2)) * millimeter, vector(0, 0, eLength-(definition.lPiston/2))*millimeter)
mirror(context, id + "mirror3", {
"patternType" : MirrorType.FEATURE,
"instanceFunction" : {},
"mirrorPlane" : qCreatedBy(id + "plane1", EntityType.FACE)
});<br>
MichaelPascoe
Member Posts: 2,814 PRO
Hi @sebastian_rigger837, you could try something similar to this: Sweep > Mirror > Boolean
Comments have been placed in the code for easier understanding of what each component does.
When using featurescript, you can use the opPattern operation to copy parts in various ways of transform.https://cad.onshape.com/documents/343178350105cea556ab3d23/w/990bfe172e0ed3c440868636/e/a7b94e644da0af9ed6cb77adFeatureScript 1821; import(path : "onshape/std/geometry.fs", version : "1821.0"); annotation { "Feature Type Name" : "Sweep Mirror" } export const sweepMirror = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Profile to sweep", "Filter" : EntityType.FACE } definition.profile is Query; annotation { "Name" : "Sweep path", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 } definition.path is Query; annotation { "Name" : "Mirror mate", "Filter" : BodyType.MATE_CONNECTOR || BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 } definition.mirrorMate is Query; annotation { "Name" : "Targets", "Filter" : EntityType.BODY } definition.targets is Query; } { // Sweep profile along path opSweep(context, id + "sweep1", { "profiles" : definition.profile, "path" : definition.path }); // Get the swept part const sweptPart = qCreatedBy(id + "sweep1", EntityType.BODY); // Turn the mate connector into a coord system const mirrorCsys = evMateConnector(context, { "mateConnector" : definition.mirrorMate }); // Create a construction plane to mirror accross const mirrorPlane = plane(mirrorCsys); // Pattern is used to copy and mirror things opPattern(context, id + "pattern1", { "entities" : sweptPart, "transforms" : [mirrorAcross(mirrorPlane)], // Transform is placed inside an array [] "instanceNames" : ["Copy"] // Names are placed inside an array [] }); // Get the mirrored parts const mirroredParts = qCreatedBy(id + "pattern1", EntityType.BODY); // Debug the parts green debug(context, qUnion([sweptPart, mirroredParts]), DebugColor.GREEN); // Boolean subtract the parts from the target opBoolean(context, id + "boolean1", { "tools" : qUnion([sweptPart, mirroredParts]), "targets" : definition.targets, "operationType" : BooleanOperationType.SUBTRACTION }); });
RENDERCAD
________________________________________________________________________2
FeatureScript 1821; import(path : "onshape/std/geometry.fs", version : "1821.0"); annotation { "Feature Type Name" : "Sweep Mirror" } export const sweepMirror = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Profile to sweep", "Filter" : EntityType.FACE } definition.profile is Query; annotation { "Name" : "Sweep path", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 } definition.path is Query; annotation { "Name" : "Mirror mate", "Filter" : BodyType.MATE_CONNECTOR || BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 } definition.mirrorMate is Query; annotation { "Name" : "Targets", "Filter" : EntityType.BODY } definition.targets is Query; } { // Sweep profile along path opSweep(context, id + "sweep1", { "profiles" : definition.profile, "path" : definition.path }); // Get the swept part const sweptPart = qCreatedBy(id + "sweep1", EntityType.BODY); // Turn the mate connector into a coord system const mirrorCsys = evMateConnector(context, { "mateConnector" : definition.mirrorMate }); // Create a construction plane to mirror accross const mirrorPlane = plane(mirrorCsys); // Pattern is used to copy and mirror things opPattern(context, id + "pattern1", { "entities" : sweptPart, "transforms" : [mirrorAcross(mirrorPlane)], // Transform is placed inside an array [] "instanceNames" : ["Copy"] // Names are placed inside an array [] }); // Get the mirrored parts const mirroredParts = qCreatedBy(id + "pattern1", EntityType.BODY); // Debug the parts green debug(context, qUnion([sweptPart, mirroredParts]), DebugColor.GREEN); // Boolean subtract the parts from the target opBoolean(context, id + "boolean1", { "tools" : qUnion([sweptPart, mirroredParts]), "targets" : definition.targets, "operationType" : BooleanOperationType.SUBTRACTION }); });RENDERCAD
