Different Scaling in Cura and in Onshape
dian_shengdian_sheng Member Posts: 2 EDU
In Onshape, I have set the dimensions correctly however when I download the STL file and import it to Cura, the dimensions are all wrong. What is the problem?
  • antlu65antlu65 Member Posts: 61 EDU
    edited August 2022
    In the Part Studio, the dialog for exporting an STL file has an option for selecting Units. You may have tried changing this, but I am pointing it out just incase. I had a similar issue, where I would define dimensions in my Part Studio in millimeters, while I was exporting STL with units of centimeters. If you link the document you are working on, I could try exporting to Cura.
