sheet metal always 3 layer with convert
bård_olsen
Member Posts: 17 ✭
Hello.
I have tried to use the sheet metal tool, to modify even the simplest of sketches, and i need to use the convert feature to get the sketches correctly into the sheet metal.
Problem is, even a simple square sketch with nothing on it ends up with 3 layers in sheet metal, and i am unable to do anything.
All i did was press the sheet metal button, select PART 1 as convert from the extrude 1...since i cannot select the surface from the sketch 1.
This seems to prevent me from bending or doing anything in the sheet metal tool...
Hope someone can tell me how to fix this.
Thanks
eric_pesty
Member, pcbaevp Posts: 2,603 PRO
I would recommend doing the training on sheet metal...
"convert" creates sheet metal from all the faces of the part you select. If you read what it says in the different input boxes, you would be able to tell you can exclude specific faces and pick which edges to bend. Try skipping the extrude and using the "thicken" sheet metal option instead...1
When you pick a rectangular extrude to convert it creates 6 sheet metal parts, on eon each sides and you can exclude some faces and pick which edges to make into bends to connect the different parts.
https://learn.onshape.com/learn/course/simultaneous-sheet-metal/getting-started-with-simultaneous-sheet-metal/what-is-simultaneous-sheet-metal
Or
https://www.onshape.com/en/resource-center/videos/designing-in-sheet-metal
If you can't, the original solid was on the cusp of failure and you're lucky.
If you're using feature script, it should match up with the user interface and enclose. You can always look at the enclose command and see how onshape did it.
Twitter: @BryanLAGdesign
