Folders in Part Studio or Assembly Tree?
Hello!
I've run into this in both part studios and assemblies (although mostly assemblies), where I'd like to just clean up my tree by being able to hide or show all "like" components. I.e., what I've often done in the past is put all pneumatic fittings into a "FITTINGS" folder within the tree so I don't have hundreds of inconsequential parts taking up space. Then I can hide/show them as needed.
Is there a way to do this in Onshape?
Thanks!
Matt
Thanks!
Matt
However, that functionality is not currently available for assemblies. You can vote for the improvement request here: https://forum.onshape.com/discussion/12562/folders-in-assembly
Then, you will be notified when the status changes.
