Separate single parts from multi-body-part
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
in General
Hello everyone,
If I create a multi-body-partstudio and after that I decide somehow one part should be in a separate partstudio. Is there a way to separate one part out of the multi-body-partstudio?
Or is working with "in Context" from the begining the only/best option?
Best regards,
Axel Kollmenter
Axel Kollmenter
Axel Kollmenter
It might be best to explain why you want to separate the part. There may be different solutions.
Axel Kollmenter
The only way I can think off is to copy the part studio and delete all the features you don't want.
If the parts were mostly independent in the first place it shouldn't be too much work, otherwise derive/delete part but that leaves all the features behind.
Axel Kollmenter
