Can sweep-as-surface, but not as-surface?
matthew_stacy
Member Posts: 489 PRO
in General
I am struggling to sweep a circular profile along a helical path with tangential entry and exit tails. As a swept-surface this is successful, and can be subsequently enclosed to make a solid.
However the sweep fail when swept as a solid. Any thoughts or ideas as to what I might be doing wrong? Both sweep operations utilize the same sketch profile ("wire") and the same path (composite-curve named "path").
I suspect that the problem lies at the intersection of tail and helix, but I am troubled by the fact that the intended geometry can be created by enclosing a swept surface.
Twitter: @BryanLAGdesign
I've definitely seen this issue before in Solidworks, so I assume it's a Parasolid issue, but it does seem like a basic enough thing that should just work. I would report this to Onshape as a bug.
Oops. I didn't look that carefully at the tails and assumed you had made them tangent. That is an issue in terms of modeling a real torsion spring, but I agree, if it can sweep the surface, why does it barf on the solid?
