Highlight a mate connector using an entity in a table row
monroe_weber_shirkmonroe_weber_shirk Member Posts: 103 EDU
edited August 2022 in Community Support
I'm creating mate connectors with attributes that I'll display in a table. I'd like to highlight the mate connector corresponding to the table row. I've done this with other bodies. When I select a row in the table where I've set the mate connector as the relevant entity, the mate connector doesn't respond. I can make adjacent lines highlight, but I'd like to highlight the mate connector. Is there a way to make a mate connector highlight when its row is selected in a table?
  • monroe_weber_shirkmonroe_weber_shirk Member Posts: 103 EDU
    How does Onshape highlight mate connectors when you mouse over the feature that created the mate connector? I'd like to be able to use that same system in a custom table to highlight the mates that correspond with each row.
