Insert element no longer working
alex_glossopalex_glossop Member Posts: 1 EDU
Hi all,
randomly the small plus sign in the bottom left hand corner of my on shape screen (insert new element) has stopped working. I have no idea if this is something i have done or not but it appears to be the same across all of my files.
Any help would be greatly received!
  • S1monS1mon Member Posts: 3,375 PRO
    Are you looking at a Version or a Workspace? If you're in a version, you can't change it.
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 559 ✭✭✭
    I think it has something to do with your browser, are you sure you are using Chrome?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
    Try clearing the browser cache and refreshing.
