Bounding Box of Sketch
amir_moazamiamir_moazami Member Posts: 7
Hi! I'm trying to get the bounding box of "Sketch 3" here in featurescript. I'm running: var tb = evBox3d(context, {topology: qSketchRegion(makeId("F23l6D73UPvFFQE_4"), false), tight: true}); but I'm getting the following error:
@evBox: CANNOT_RESOLVE_ENTITIES
What am I doing wrong?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Using makeId is a BAD idea since that id could change - when you create the sketch, you assign an id such as id + "sketch" - use that.
  • amir_moazamiamir_moazami Member Posts: 7
    i fixed. it gives the same error though :( maybe because the entities do not form closed loop?
    Nope - post all your code or make the doc public, please.
