Dimension for wraped arc
amir_livne
Member Posts: 85 ✭✭
in Drawings
Hi
I'm wondering whether there us an option to give dimensions fir wrapped arcs or circles as in the attached example
Thank you
Thank you
The 25 dimension on the section is not very useful. What are you inspecting? There’s no tangent line on a real part.
I might dimension the width and height of the slots, and possibly mark the ends as FULL R, but depending on what you need to control all of the slot dimensions might be controlled by an overall profile tolerance and a 3D file.
Similarly the slots on the flange would make more sense as width x length.
