When using frames is there a way to have an off center pattern.
glen_dewsbury
Member Posts: 1,295 PRO
I see that frame profiles is deciding geometric center/origin for the profile. Is there a way to offset the profile? I have something that wants an offset to match with a previous frame but unable to set location myself. In this particular application the origin wants to be outboard of the profile.
It would be nice if you could pick a mate connector for the frame "pierce point" for maximum flexibility (like the "transform pattern" custom feature)
Here's an improvement request worth voting on: https://forum.onshape.com/discussion/18620/add-custom-locator-points-to-frame-profiles#latest
