where is the countersink?
glen_dewsburyglen_dewsbury Member Posts: 1,268 PRO
Ran into this just now. Asked for a countersink hole but no countersink. What did I miss?
https://cad.onshape.com/documents/12b0679a712bc6f544f72c07/w/67e973d9c8c7d9393a467fa0/e/e00742e616227d98d43069ae
  • Connor_RConnor_R Member Posts: 4 PRO
    Your hole diameter and countersink diameter are input as the same value.  If you set the second input to your desired countersink size, you should be good.
  • glen_dewsburyglen_dewsbury Member Posts: 1,268 PRO
    I sent this to support and they acknowledged a need to correct.
    edited October 2022
    Kinda odd that this is the default on an M7 hole. When I switch to another size I get an expected result.
    Most times the default saves me looking up countersink size. Looks like a glitch in the table values.
