Radial attachment of part on cylinder
Cylindrical Mate with Limits, provided the outside face of the rocket, and the part of the fin that touches the rocket, both have the same radius
https://cad.onshape.com/documents/890aeb7dcf81d91801cc91c5/w/889552ad99e850010f17c77a/e/46b878188c8cb3e790fbffd9
That's just a fasten mate with a Z offset (rather than cylindrical with limits...)
@felix_meyer213
There is no "fix" mate. Fix just makes a part immovable but not relative to any other part, best practice is to "fix" one part in you assembly and then mate the other ones from there.
I would suggest doing the training on assemblies, it goes over the different types of mate: https://learn.onshape.com/learn/course/fundamentals-onshape-assemblies/creating-an-assembly/starting-an-assembly
They are similar. But not quite the same
During your design stage, the cylindrical mate is easier for you to move around and look at, and then move it a little bit more, and look at it. So if you’re the sort that likes to design that way — as might be the case if you were designing a toy rocket, then cylindrical is what you might want to use
You could also be designing some type of a consumer product that has a cylindrical aspect to it and you were going to be attaching something to the cylinders surface in a similar manner, and this item was something that you were going to be moving a lot until you dialed in the exact location. Cylindrical could come in handy in this case also
But it was great that you showed how there are a few ways to go about this particular situation
