extrude on an angle
jeff_mcaffer
Member Posts: 98 ✭✭✭
Any suggestions?
Jeff
p.s., I tried attaching a screen shot of this but that feature doesn't seem to work (for me at least). You can see an example in 1010 | Part Studio 2 (onshape.com)
eric_pesty
Member, pcbaevp Posts: 2,605 PRO
There are a few ways you could do this:
- create the angled plane first and change the end condition for the extrude to "up to entity" (and select the plane)
- Do a "move face" using the rotate option and the edge you used for the plane as the axis to angle the top of the wall (then you don't need the plane anymore)
- Don't change anything and do a "replace face" to move the walls up to the roof:
See example: https://cad.onshape.com/documents/c9c3a9e645c57908a5c72137/w/bf224f26f73bf67e27a111b6/e/1a10b548a76d2554be863cb6
As a side note, best practice is to fully define sketches and in a case like this to place them in a "logical" place on the origin.
2
Basically at a high level you either need to create the angled reference first to "extrude up to", or use a second feature to modify it in which case there are a number of ways to achieve that (move/replace face, second extrude, etc...)
Then there are also other ways you could approach this by extruding from the side first (to create the sloped roof) and then doing either a cut from the top or use a "shell" to create "hollow out" the inside.
