Editing sheet metal in flat
I'm facing this issue with sheet metal designing since it's being done when it's already bent.
Any tips?
Any tips?
bryan_lagrange Member, User Group Leader Posts: 887 ✭✭✭✭✭
Can you post the link to review the part?
Not sure what you are looing for.
option A:
option b:
option c:
Here is the example of the cut in the flat up to the bend line. Like @glen_dewsbury mentioned you would open the flat pattern window and create a sketch there.
glen_dewsbury Member Posts: 1,120 PRO
Ofer. Don't forget that you can roll back in the feature tree to before the 'finish sheet metal model' to make adjustments with out loosing the finished sheet metal model and other features in between.1
option A:
option b:
option c:
Twitter: @BryanLAGdesign
https://cad.onshape.com/documents/12b0679a712bc6f544f72c07/w/67e973d9c8c7d9393a467fa0/e/ef369ebb7ce4e808d54a9d62
I couldn't find a way to flatten it in order to cut it like in option b., it, the way I would normally do on SolidWorks.
https://cad.onshape.com/documents/9923a51553903c4e2d3c90e3/w/ca163c507a804753c56e986e/e/66a43bf08bf7b9f165f7b287?renderMode=0&uiState=6346f87940b40c0a16c3b6a5
You just have to keep adding to your initial part.
Thanks for your answer
