Making a hollow dome
How do I make a hollow dome so that it is attached to the bottom part?
I have tried using loft but could not figure it out.
- Revolve the dome as a new surface.
- Thicken add the surface as a solid part to the main solid part.
Don't forget to check out the Learning Pathways at the Onshape Learning Center. They are very valuable.https://cad.onshape.com/documents/e3e30d828
It's hard to know exactly what you want, and of course there will be a million ways to do it, but here's one way.
