different angle
First day ! I have drawn my shape on the top plane, it's a triangle that is 4mm deep. Now I want to draw another rectangle to join one of the edges, but at a different angle to the plane, let's say the first shape is flat, horizontal and I want the second shape to rise approx 30 degrees to the horizontal. Every time I draw the second shape, it remains horizontal ! How can I rotate it to 30 degrees above the horizontal line ?
Or is there a good you tube I can watch that will explain this ? TIA
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 949 PRO
    One option would be to sketch on the Right plane.  Then extrude your new geometry it.  Try "symmetric" or "up to vertex" for end type.
  • norman_pimlottnorman_pimlott Member Posts: 4
    Exactly that, but it doesn't work for me ! for some reason it swans off to one side, and I can't get the angle on screen, so it's just at whatever angle I draw it. I draw a line 40mm long 4mm thick then try to extrude it to the 66mm, but it attaches to the centre and goes 66mm left. Oh and I can't find Symmetric.
