multi DXF. File Export as a set
josh_mandel
Member Posts: 7 PRO
I would like to be able to export those 4 dxf. files as one, Is there a way to do that? It would save me a lot of time. Thanks
eric_pesty
Member, pcbaevp Posts: 2,565 PRO
I think your best bet is to create a blank drawing (no title block) and insert them in there (you can use a custom sheet size that would fit all of them 1:1), then you can export that1
