Is there a better/faster way?
I have a drawing where I used a configuration variable to drive one dimension within a parts studio, I then used another configuration variable in the assembly to again alter the same dimension, so far straight forward. I then decided that instead of using a variable I want to use a list with set dimensions, no problem in the parts studio but in the assembly unlike with the variable where you can right click, 'select all instances with the same configurations' and then clicking on 'configuration', job done. With a list configuration it looks like the only way is to click on each individual part in the parts tree to add it to the configuration list, once you have finished selecting all the parts that are affected by the dimension change and you have clicked 'done', you then need to select from the drop down in the configurations what you want to happen for each cell in each row in every column. My problem is that I have 10 rows and most of the assembly is driven by this dimension, approximately 150-200 parts x 10 is a lot of cells to set.
Is there another way, any help would be much appreciated and could save me a lot of time?
If you have lots of parts you need to select you will still have to find a way to pick them in the tree (remember you can use the filter to help with that) but the key point is that you don't have to edit every cell in the configuration table.
See example where blocks with different heights and different colors can be configured at once and it only changes the edited property (you can set them to the same color without changing the height or to the same height without changing the color)
so it just took me a few minutes longer and it hadn't annoyed me enough yet to find a better way.
My main issue in this regard is actually that I have all of these configurations set in configuration tables
so if I have 10 of the same part with the same configuration I have 10 of the same entries in my configuration
table and it gets a bit unwieldy. Besides using linear patterns where you can is there another way you would
handle this issue and is it something you come across as well?
