Draft Issue, Selected surfaces cannot be drafted
jason_murray495jason_murray495 Member Posts: 2
edited October 2022 in Community Support
Hello all,
I have tried everything I can think of and done a whole lot of googling but can't figure out how to apply a draft to the part I am working on. The problem draft (8) is the last feature.
Any tips would be appreciated, thanks
https://cad.onshape.com/documents/252c6e2ff7c59e684f3930b3/w/aef06d6bdb163e0c3ed09300/e/06b8d3b63ea7a39ae5be365d
  • S1monS1mon Member Posts: 4,061 PRO
    Fillet 2 and Fillet 4 are interacting it a very weird way (see highlighted edges). If you have very simple shapes, applying draft after filleting with "reapply fillets" will work, but in a complex situation like this, it's bound to fail.
    It's usually much better to apply draft earlier in the process and add those smaller fillets later.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    There are also many things "wrong" with this model e.g. very first sketch has overlapping geometry, no tangency in Sketch4, 2 transforms and a delete part to correct a mistake, 80 features, etc. This all results in bad geometry which will make adding draft and fillets much harder. The art to a good parametric model is to keep things simple and go back to fix earlier features to correct a mistake rather than add more.
