Onshpe API: How to export a Part Studio to a Step file
zhou_shengdi
Member Posts: 1 EDU
Hello, Team.
I want to get and export a step file from the Onshape Server using the Onshape API through a browser. What should I do? Thanks.
I don't know Onshape API, maybe you are thinking of Featurescript ?
You only said that you want to export a step file, but is that of a Part, part studio, assembly?
Part studios have an API endpoint for translation
https://cad.onshape.com/glassworks/explorer/#/PartStudio/createPartStudioTranslation
Which is also covered in the documentation
https://onshape-public.github.io/docs/translation/
