Animatio
amir_livne
Member Posts: 85 ✭✭
in General
Hi everybody
I'll appreciate if someone can show me hoe to create animation in such mechanism
Thank you
Amir
Thank you
Amir
The animation doesn't get the full range of motion at the end of the slot because of the complex motion (the pin in the main slot has to go back down to get the other pin to the end of the angled slot). As far as I know, Onshape can't animate that sort of motion. But you can manually drag it through all the positions:
Lead Mechanical Engineer @ Healing Innovations
https://forum.onshape.com/discussion/10484/rubiks-cube-mate-animation/p1
