Code Blocks broken in Forum
S1monS1mon Member Posts: 3,339 PRO
It seems I’m not the only one who has major issues with trying to use Code Blocks in the forums. Can someone at Onshape please look into this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,864
    Create the code block first then paste code into it.
  • S1monS1mon Member Posts: 3,339 PRO
    Testing...
    export enum BridgingCurveMatchType
        annotation { "Name" : "Match position" }
        POSITION,
        annotation { "Name" : "Match tangent" }
        TANGENCY,
        annotation { "Name" : "Match curvature" }
        CURVATURE
    Let's see if this works...
    OK. Wow. I could swear that it used to be that you could paste first and then format.
    Maybe years ago but it’s been broken for a long time.
    The "quote" block will work if you format after the fact.
